Readsoft Invoices
Capturing data from structured forms such as order forms, questionnaires, applications and claims can be an unrewarding and expensive manual exercise. Readsoft Forms automates this task and provides you with substantial savings and improved workflow.
e-Docs UK has used Readsoft Forms for many years and can testify to its speed and accuracy.
Automating information extraction from structured and semi structured forms
Readsoft Forms will capture data from any type of form in any format
  • Paper forms
  • Fax forms
  • Internet forms
  • E-mail
  • XML files
  • PDF files
  • Digital images - TIFF, JPG, PNG, BMP etc.
  • Digital pens
The software reads hand-written text, machine-print, barcodes, check boxes, circles, tables, matrixes — pretty much everything.
What will this do for your business?
Time - Automatic forms processing is much faster than the tedious manual keying of information.
Money - You need to allocate far less resources on forms processing.
Information quality - Its powerful interpretation engine is very accurate. The software is also programmed to ask for verification whenever it is not 100% certain. This means that errors are reduced to a minimum.
You can buy with confidence from a user who has an extensive understanding of the software and can also demonstrate in a real life environment.
Contact
Contact us to find out more about how we can help you manage your documents more efficiently, reduce your administration costs and improve your own customer service.
Tel: +44 (0)1992 801 860
E -mail: sales@e-DocsUK.co.uk
Customer Solutions:
We enabled a food distribution company to reduce capture costs from 20,000 delivery notes per week by using Readsoft Forms capture software.
